Not sure why Im not seeing an apply button in Face recovery after I’ve selected the faces to be recovered
Hi Luclous. Recover Faces is applied automatically to any faces that Photo AI detects.
If however, Photo AI is unsure and doesn’t select a face but, places a gray box around it. You can decide if you want to highlight the box and Photo AI will automatically update the image for you.
If you look in the bottom left hand corner you’ve see a process bar when the bar turns gray the image has been updated.
There’s a bug in Photo AI that sometimes doesn’t update the image on screen when you press the Space Bar for a Before and After, to fix this simply click once with the mouse button anywhere on the image now, press the Space Bar again and the Before and After will now work
Hope this works
Thanks And-e
