This is a pity because it is a very powerful function for which I mainly use the Topaz.
Most of the time a part of the neck is not included, so there is visually a hard edge between the enhanced blurred face and a part of the neck.
Why is there no way to manually adjust the mask if it doesn’t fit automatically?
I then always have to rework the rest of the skin areas manually in Pgotoshop and get annoyed with every update that it still doesn’t work better.
Hi, there is an option within preferences under the Edit menu to select Hair & Neck.
However, what you’re experiencing is common with facial recognition software (face detect).
I normally do two instances of the same image, one with Face Recovery and the other using Denoise and Sharpen without Face Recovery, then blend the two together within Photoshop or your chosen image editing software.
Hope this helps
