Can the hair and neck toggles for face recovery be moved to the main face recovery options instead of having to go into the preferences menu.
Thanks for your suggestion. Do you envision it looks like the different models for the other filters except instead of Normal or Strong under Sharpen for example, it says Hair and Neck for Face Recovery and they can be checked off?
