Face Recovery going Idle
[ Anytime I try to use face recovery it goes Idle and will just stop working. Try to include logs (Help → Logging) and add screenshots if necessary.]
2024-03-17-23-38-59.tzlog (73.6 KB)
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Topaz Labs Download Page
I have tried multiple times to uninstall the software and reinstall it following the steps, but it still freezes when I try to activate the facial recognition feature.
2024-03-22-08-59-58.tzlog (111.1 KB)
Please reach out to us at the following link:
Topaz Labs | Support Page
You can also send an email to help@topazlabs.com
