Face recovery, distorting hair, hats, and creating large block like artifacts
While using face recovery, individuals with hats or long hair tend to get distorted, as well as large block, like artifacts, showing up on hats as well as the neck lines given lizard like skin texture.
Would you mind sending in some more information to better understand the problem you are having with these images while using Face Recovery? Please send the following information:
  1. The original image file.
  2. The processed image.
Dropbox File Request
