The IRIS model should have a ‘Face Detection Strength’ slider to control that feature, because it makes many mistakes that can’t be fixed due to the lack of this parameter.
The slider should go all the way down to DISABLED or OFF, because you may want to use the model but not the face recognition feature AT ALL.
This should be TOP priority for next release, very important!
Low quality highly compressed video faces can look really awkward!
For now it would be enough a setting to turn off face detection altogether. They say that Proteus can replace Iris, I think othervise.
I also have better results using IRIS than Proteus, but faces appear in wrong places or look too different from the rest of the image, which ruins the whole process.
