Face Detection Hanging
I’ve just updated and now Face Detection won’t work. Auto pilot tries to run it but it just sits there spinning forever and Autopilot never completes, and now all of Topaz is ‘broken’ because you can’t get past that once it tries to load an image.
As of Sunday Feb 4 2024
Topaz Photo AI 2.3.1 on Windows
Please supply all of the required information such as PC specs, logs etc.
What logs? From where? How do I obtain them for you? I’m on a 64k Win 10 PC. I’ve no clue what my processor/v-card etc. is. Explain how/where to obtain what you need and I’ll see what I can do.
Thanks for reaching out to us on our support page.
Our developers are currently working on this issue and will resolve it quickly.
You can choose one of these two workarounds to resolve this issue:
  • Disable the Autopilot in the app’s Preferences > Autopilot menu
  • Uninstall the current application version and then revert back to Topaz Photo AI v2.3.0 using the following download link: Topaz Photo AI | v 2.3.0 | Windows Installer
Thanks!
I’ll do the former for now and await an updated download with a fix in the meantime.
Appears a lot of users are having the same issue, I doubt it’s a specific device issue. I ended up installing the old version 2.3.0 and things seem to be working again. I did have to run a repair after I ran the install as it appeared it removed the latest version but failed to install the older version. I then rebooted and ran the install again and selected repair and it installed all the files and it is no longer hanging at detecting faces. I’m really surprised they allowed something like this past the testing stages. I would recommend Topaz to remove the update so unexpected customers do not install what I would consider a major bug.
Here’s the link to the previous version: https://downloads.topazlabs.com/deploy/TopazPhotoAI/2.3.0/TopazPhotoAI-2.3.0.msi
I think you might be wrong as a Win 11, AMD Ryzen 9 6900HX, RAM 32GB, NVIDIA RTX3060/6GB with Driver version 551.23 (Studio) has absolutely no issue.
There also was a report on the forum where AMD GPUs were having was having issues with Photo AI an the OP downloaded a fix from AMD forums …
Having the same problem. Autpilot is the default, but the program just hangs at face detection. There is a little lock symbol next to face detection and it reads “face detection not run”. Also cannot disable autopilot! Even tho’ you disable the filters in the preferences section, autopilot continues to run and nothing progresses - no loading image, no detecting subject, no face detection, etc. You cannot manually select a filter to apply, either. This release is really a hot mess! Windows 10 desktop.
It gets stuck on Autopilot face recognition and loops there forever. I have turned off auto-pilot and filters (and saved that) but it does not turn off.
An suggestion on how to get the older version back (it worked fine).
I paid a lot of money for this and it is impossible to use!
Lyle M.
Turn off Face Recovery in the settings (open as a standalone)
Also you post about a issue without the required information, PC specs, Logs etc.
  • Like @AiDon said disable the Autopilot in the app’s Preferences > Autopilot menu
Program keeps hanging up at detecting faces stage in autopilot. Did not happen before last update.
I concur!
When I open Photo AI ver 2.3.1, it says “Face Detection Not Run”.
It worked perfectly in the previous version.
Please rectify this ASAP!
John Villumsen
Just to say I use GigapixelAI which I like. I downloaded the demo 2.31 version of PhotoAI to see if it would help me with other image issues but unfortunately I ran straight into this bug (Spec: Windows 10, NVidea GeForce 1070Ti). Attempting to disable the Autopilot feature did not work which also leaves me a little dismayed that this application is incomplete and not yet PROD ready.
I was seriously considering purchasing this application but unfortunately this experience has put me off for just now.
I have the same issue since update to 2.3.2 - it was working prior to the update but it now totally unusable. This is a major issue for me. Please FIX IT.
Adobe Photoshop Version: 25.5.0 20240214.r.375 c4f33ec x64
Number of Launches: 68
Operating System: Windows 11 64-bit
Version: 11 or greater 10.0.22631.3155
System architecture: Intel CPU Family:6, Model:14, Stepping:12 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 8
Processor speed: 3600 MHz
Built-in memory: 32705 MB
Free memory: 20965 MB
Memory available to Photoshop: 25140 MB
Memory used by Photoshop: 70 %
Crash Handler: Adobe
DCX Version: 7.13.2
SAM SDK Version: 7.6.0-fio
ACP.local Status:
  • SDK Version: 3.4.0
  • Core Sync Status: Reachable and compatible
  • Core Sync Running: 7.0.0.9
  • Min Core Sync Required: 4.3.66.28
    Live Edit Client SDK Version: 4.0.4
    Open Color IO version: 2.3.2
    C2PA library version: adobe_c2pa/0.7.6-2 c2pa-rs/0.25.2-patch
    NGL Version: 1.36.0.10
    Chalkboard: Disabled.
    D3D12Warp renderer: Disabled.
    Manta Canvas: Enabled.
    Alias Layers: Disabled.
    Highbeam: Enabled.
    Image tile size: 1024K
    Image cache levels: 4
    Font Preview: Medium
    HarfBuzz Version: 7.3.0
    TextEngine: Unified Text Engine
    ======= GPU
    Native API stable: True
    OpenGL API stable: True
    OpenCL API stable: True
    GPUDeny: 0
    GPUForce: 0
    useGPU: 1
    useOpenCL: 1
    isGPUCapable: 1
    GPUName: NVIDIA GeForce GTX 1650
    GPUVendor: NVIDIA
    IsNativeGPUCapable: 1
    IsOpenGLGPUCapable: 1
    IsOpenCLGPUCapable: 1
    HasSufficientRAM: 1
    GPU accessible RAM: 3,937 MB
    Required GPU accessible RAM: 1,500 MB
    UseGraphicsProcessorChecked: 1
    UseOpenCLChecked: 1
    Windows remote desktop: 1
    Windows available feature level: 12.1
    Windows required feature level: 12.0
    Windows has required feature level: 1
    Display: 1
    Display Bounds: (0, 0) → (2880, 1620)
    Display scale: 2
    Display Type: SDR
    ------- Sniffer output
    [0 ms]
    Launch GPUSnifferThread
[1 ms]
Start RunAllAPIs
[1 ms]
“C:\Program Files\Adobe\Adobe Photoshop 2024\sniffer.exe” -baseTimeMS=88909372 -comment=Photoshop Version: Adobe Photoshop 25.5.0 20240214.r.375 c4f33ec x64
[1 ms]
Start GetSnifferResult
[883 ms]
Start sniffer 2024-02-27 16:32:16
C:\Program Files\Adobe\Adobe Photoshop 2024\sniffer.exe -baseTimeMS=88909372 -comment=Photoshop Version: Adobe Photoshop 25.5.0 20240214.r.375 c4f33ec x64
{85 ms}
Start platform native
# displays: 1
Display 0
Display: \.\DISPLAY81
Main: TRUE
Built in: FALSE
Stereo: FALSE
Bounds: (0, 0) → (2,880, 1,620)
Dimensions: (2,880 1,620)
Display scale: 2
Physical size: (0 0)
Pixel size: (0 0)
Dynamic range: (0 1)
Potential dynamic range: (0 1)
Reference dynamic range: (0 1)
Attached Device: (DeviceID name=NVIDIA GeForce GTX 1650 index=0)
# devices:                    2
Device 0
  Preferred:                    TRUE
  Power Envelope:               UNKNOWN
  Attachment:                   UNKNOWN
  # attached displays:          1
    \\.\DISPLAY81
  VRAM:                              3,937 MB
  Dedicated System RAM:                  0 MB
  Shared System RAM:                17,146 MB
  API version:                  12.0 (12.0)
  Device version:               12.0 (12.0)
  Vendor name:                  NVIDIA
  Driver date:                  2024-02-15  000000.000000-000
  Driver age:                   0 months
  Driver version:               31.0.15.5161
  Supports UMA:                 UNSUPPORTED
  D3D-ID:                       8066
Device 1
  Preferred:                    FALSE
  Attachment:                   UNKNOWN
  # attached displays:          0
  VRAM:                              3,937 MB
  Vendor name:                  NVIDIA
  D3D-ID:                       8066
End platform native
{296 ms}
{296 ms}
Start platform OpenGL
# displays: 1
Display 0
Main: TRUE
Built in: FALSE
Stereo: FALSE
Display scale: 2
Pixel size: (0 0)
Attached Device: (DeviceID name=NVIDIA GeForce GTX 1650/PCIe/SSE2 index=0)
# devices:                    1
Device 0
  Name:                         NVIDIA GeForce GTX 1650/PCIe/SSE2
  Preferred:                    TRUE
  Power Envelope:               INTEGRATED
  Attachment:                   UNKNOWN
    \\.\DISPLAY81
  GPU accessible RAM:                4,128 MB
  VRAM:                              4,128 MB
  API version:                  2.1 (2.1.2 NVIDIA 551.61)
  Device version:               2.1 (2.1.2 NVIDIA 551.61)
  Vendor name:                  NVIDIA
  GLSL version:                 1.20 (1.20 NVIDIA via Cg compiler)
End platform OpenGL
{537 ms}
{537 ms}
Start platform OpenCL
# displays: 0
# devices:                    1
Device 0
  Preferred:                    TRUE
  Power Envelope:               DISCRETE
  Attachment:                   UNKNOWN
  GPU accessible RAM:                4,294 MB
  VRAM:                              4,294 MB
  Shared System RAM:                     0 MB
  API version:                  3.0 (OpenCL 3.0 CUDA)
  Device version:               3.0 (OpenCL 3.0 CUDA)
  Vendor name:                  NVIDIA
  Driver date:                  UNKNOWN
  Driver age:                   UNKNOWN
  Driver version:               UNKNOWN
  Bandwidth:                    109 GB / s
  Compute score:                1,236.44
  Device name string:           NVIDIA GeForce GTX 1650
  Device vendor string:         NVIDIA Corporation
  Platform name string:         NVIDIA CUDA
  Platform vendor string:       NVIDIA Corporation
End platform OpenCL
{787 ms}
Exit code kExitNormal
End sniffer 2024-02-27 16:32:17
[kStatusNormal, kExitNormal]
[883 ms]
Finish RunAllAPIs
[886 ms]
Finish GetSnifferResult
======= GPU
License Type: Subscription
Serial number: 96040890593664719731
GUIDBucket:
Composite Core GPU (comp_core_gpu): off
Composite Core Threads (MultithreadedCompositing): on
Composite Core UI (comp_core_ui): off
Composite Core Feature Prefs (CompCoreFeaturePrefs): off
Document Graph (DocumentGraph): off
Application folder: C:\Program Files\Adobe\Adobe Photoshop 2024
Temporary file path: C:\Users\kcts\AppData\Local\Temp
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 494.9G, 252.9G free
Required Plugins folder: C:\Program Files\Adobe\Adobe Photoshop 2024\Required\Plug-ins
Primary Plugins folder: C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\
Installed components:
ACE.dll ACE 2023/11/23-09:21:32 151.d526588 151.d526588
act_tracing.dll Copyright (c) 2021 Adobe. All Rights Reserved 1.0.58
AdobeLinguistic.dll Adobe Linguisitc Library 2d5dab2
AdobeOwl.dll Adobe Owl 5.5.0
AdobePDFL.dll PDFL 2023/11/07-13:18:05 79.82c92b1 79.82c92b1
AdobePIP.dll Adobe Product Improvement Program 8.2.0.16
AdobeSVGAGM.dll AdobeSVGAGM 79.4d9d554 79.4d9d554
AdobeXMP.dll Adobe XMP Core 2023/11/09-12:40:27 79.f354efc 79.f354efc
AdobeXMPFiles.dll Adobe XMP Files 2023/11/09-12:40:27 79.f354efc 79.f354efc
AdobeXMPScript.dll Adobe XMP Script 2023/11/09-12:40:27 79.f354efc 79.f354efc
AGM.dll AGM 2023/11/23-09:21:32 151.d526588 151.d526588
AID.dll AID DLL 1.0.0.58
AIDE.dll AIDE 2023/11/10-05:16:23 79.e59fc31 79.e59fc31
aifm.dll AIFM 1.0 23.68434
AILib.dll Adobe Illustrator 2024 28.0.0
aiport.dll AIPort 1.0 23.68434
ARE.dll ARE 2023/11/23-09:21:32 151.d526588 151.d526588
AXE8SharedExpat.dll AXE8SharedExpat 2023/11/01-19:10:59 79.a28ee6c 79.a28ee6c
AXEDOMCore.dll AXEDOMCore 2023/11/01-19:10:59 79.a28ee6c 79.a28ee6c
BIB.dll BIB 2023/11/23-09:21:32 151.d526588 151.d526588
BIBUtils.dll BIBUtils 2023/11/23-09:21:32 151.d526588 151.d526588
boost_chrono.dll photoshopdva 22.0.0
boost_date_time.dll photoshopdva 22.0.0
boost_filesystem.dll photoshopdva 22.0.0
boost_regex.dll photoshopdva 22.0.0
boost_system.dll photoshopdva 22.0.0
boost_threads.dll photoshopdva 22.0.0
CoolType.dll CoolType 2023/11/23-09:21:32 151.d526588 151.d526588
CRClient.dll Adobe Crash Reporter Client DLL 14.0.0.202310260823_2e78abe
DirectML.dll DirectML Redistributable Library 1.10.1+230125-1155.1.dml-1.10.177341d
dnssd.dll Bonjour 3,0,0,2
dvaaccelerate.dll photoshopdva 22.0.0
dvaappsupport.dll photoshopdva 22.0.0
dvaaudiodevice.dll photoshopdva 22.0.0
dvaaudiodsp.dll photoshopdva 22.0.0
dvacore.dll photoshopdva 22.0.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 22.0.0
dvamediatypes.dll photoshopdva 22.0.0
dvametadata.dll photoshopdva 22.0.0
dvametadataapi.dll photoshopdva 22.0.0
dvametadataUI.dll photoshopdva 22.0.0
dvanet.dll photoshopdva 22.0.0
dvaplayer.dll photoshopdva 22.0.0
dvascripting.dll photoshopdva 22.0.0
dvatransport.dll photoshopdva 22.0.0
dvaui.dll photoshopdva 22.0.0
dvavulcansupport.dll photoshopdva 22.0.0
dynamic-torqnative.dll Unified Extensibility Platform uxp-7.4.1-release
dynamiclink.dll photoshopdva 22.0.0
ExtendScript.dll ExtendScript 2022/08/18-12:50:45 82.4 82.4
filterport.dll FilterPort 1.1 O
icucnv73.dll International Components for Unicode Build 14.0.1.04ee3a5
icuin73.dll International Components for Unicode Build 14.0.1.04ee3a5
icuuc73.dll International Components for Unicode Build 14.0.1.04ee3a5
ippcc.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcck0.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccl9.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippccy8.dll ippCC. Intel(R) Integrated Performance Primitives. Color Conversion. 2021.6 (r0xbffe3c5b)
ippcore.dll core. Intel(R) Integrated Performance Primitives. Core Library. 2021.6 (r0xbffe3c5b)
ippcv.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvk0.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvl9.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippcvy8.dll ippCV. Intel(R) Integrated Performance Primitives. Computer Vision. 2021.6 (r0xbffe3c5b)
ippi.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippik0.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippil9.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ippiy8.dll ippIP. Intel(R) Integrated Performance Primitives. Image Processing. 2021.6 (r0xbffe3c5b)
ipps.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsk0.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsl9.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippsy8.dll ippSP. Intel(R) Integrated Performance Primitives. Signal Processing. 2021.6 (r0xbffe3c5b)
ippvm.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmk0.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvml9.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
ippvmy8.dll ippVM. Intel(R) Integrated Performance Primitives. Vector Math. 2021.6 (r0xbffe3c5b)
JP2KLib.dll JP2KLib 2023/10/17-19:30:38 79.eda3309 79.eda3309
libeay32.dll The OpenSSL Toolkit 1.0.2zg
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler Mainline
libzip.dll photoshopdva 22.0.0
LogSession.dll LogSession 8.2.0.16
mediacoreif.dll photoshopdva 22.0.0
Microsoft.AI.MachineLearning.dll Microsoft® Windows® Operating System 1.14.20230410.1.429e1e3
mkl_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_core.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_sequential.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx2.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_avx512.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_def.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
mkl_vml_mc3.2.dll Intel(R) oneAPI Math Kernel Library 2022.1
MPS.dll MPS 2023/11/07-13:18:05 79.7a67d56 79.7a67d56
onnxruntime.dll Microsoft® Windows® Operating System 1.14.20230410.1.429e1e3
opencv_world452.dll OpenCV library 4.5.2
pdfport.dll PDFPort 2020/11/19-11:34:27 79.625377 79.625377
Plugin.dll Adobe Photoshop 2024 25.5
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 11.5.2
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 11.5.2.130
PSCloud.dll 1.0.0.1
PSRes.dll Adobe Photoshop 2024 25.5
PSViews.dll Adobe Photoshop 2024 25.5
ScCore.dll ScCore 2022/08/18-12:50:45 82.4 82.4
ssleay32.dll The OpenSSL Toolkit 1.0.2zg
SVGRE.dll SVGRE 79.968b720 79.968b720
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler Mainline
VulcanControl.dll Vulcan Application Control Library 7.2.0.34
VulcanMessage5.dll Vulcan Message Library 7.2.0.34
WinRTSupport.dll Adobe Photoshop Windows RT Support 1.0.1.0
WRServices.dll WRServices Build 18.0.0.788c4ff 18.0.0.788c4ff
UPIC 2.6.0
Required plugins:
Accented Edges 25.5 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 25.5 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 25.5 - from the file “Filter Gallery.8bf”
Average 25.5 - from the file “Average.8bf”
Bas Relief 25.5 - from the file “Filter Gallery.8bf”
BMP 25.5 - from the file “Standard MultiPlugin.8bf”
Camera Raw 16.2 - from the file “Camera Raw.8bi”
Camera Raw Filter 16.2 - from the file “Camera Raw.8bi”
Chalk && Charcoal 25.5 - from the file “Filter Gallery.8bf”
Chrome 25.5 - from the file “Filter Gallery.8bf”
Cineon 25.5 - from the file “Cineon.8bi”
Clouds 25.5 - from the file “Clouds.8bf”
Color Halftone 25.5 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 25.5 - from the file “Filter Gallery.8bf”
Conté Crayon 25.5 - from the file “Filter Gallery.8bf”
Craquelure 25.5 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 25.5 - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 25.5 - from the file “Standard MultiPlugin.8bf”
Crosshatch 25.5 - from the file “Filter Gallery.8bf”
Crystallize 25.5 - from the file “Standard MultiPlugin.8bf”
Cutout 25.5 - from the file “Filter Gallery.8bf”
Dark Strokes 25.5 - from the file “Filter Gallery.8bf”
De-Interlace 25.5 - from the file “Standard MultiPlugin.8bf”
Dicom 25.5 - from the file “Dicom.8bi”
Difference Clouds 25.5 - from the file “Clouds.8bf”
Diffuse Glow 25.5 - from the file “Filter Gallery.8bf”
Displace 25.5 - from the file “Standard MultiPlugin.8bf”
Dry Brush 25.5 - from the file “Filter Gallery.8bf”
Entropy 25.5 - from the file “statistics.8ba”
Export Color Lookup Tables 25.5 - from the file “Export3DLUT.8be”
Extrude 25.5 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 25.5 - from the file “FastCore.8bx”
Fibers 25.5 - from the file “Standard MultiPlugin.8bf”
Film Grain 25.5 - from the file “Filter Gallery.8bf”
Filter Gallery 25.5 - from the file “Filter Gallery.8bf”
Fresco 25.5 - from the file “Filter Gallery.8bf”
Glass 25.5 - from the file “Filter Gallery.8bf”
Glowing Edges 25.5 - from the file “Filter Gallery.8bf”
Graphic Pen 25.5 - from the file “Filter Gallery.8bf”
Halftone Pattern 25.5 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 25.5 - from the file “HalideBottlenecks.8bx”
HDRMergeUI 25.5 - from the file “HDRMergeUI.8bf”
HSB/HSL 25.5 - from the file “Standard MultiPlugin.8bf”
IFF Format 25.5 - from the file “Standard MultiPlugin.8bf”
Ink Outlines 25.5 - from the file “Filter Gallery.8bf”
JPEG 2000 25.5 - from the file “JPEG2000.8bi”
Kurtosis 25.5 - from the file “statistics.8ba”
LandscapePro 3.1.0 - from the file “LandscapeProPSFilter64.8bf”
Lens Blur 25.5 - from the file “Lens Blur.8bf”
Lens Correction 25.5 - from the file “Lens Correction.8bf”
Lens Flare 25.5 - from the file “Standard MultiPlugin.8bf”
Liquify 25.5 - from the file “Liquify.8bf”
Luminar AI 17.0 - from the file “LuminarAI.8bf”
Luminar Neo 17.0 - from the file “LuminarNeo.8bf”
Matlab Operation 25.5 - from the file “ChannelPort.8bf”
Maximum 25.5 - from the file “statistics.8ba”
Mean 25.5 - from the file “statistics.8ba”
Measurement Core 25.5 - from the file “MeasurementCore.8me”
Median 25.5 - from the file “statistics.8ba”
Merge to Nik 6 HDR Efex NO VERSION - from the file “Nik6HDRMerge.8li”
Mezzotint 25.5 - from the file “Standard MultiPlugin.8bf”
Minimum 25.5 - from the file “statistics.8ba”
MMXCore Routines 25.5 - from the file “MMXCore.8bx”
Mosaic Tiles 25.5 - from the file “Filter Gallery.8bf”
Multiprocessor Support 25.5 - from the file “MultiProcessor Support.8bx”
Neon Glow 25.5 - from the file “Filter Gallery.8bf”
Nik 6 Analog Efex NO VERSION - from the file “NikCollection.8bf”
Nik 6 Color Efex NO VERSION - from the file “NikCollection.8bf”
Nik 6 Dfine NO VERSION - from the file “NikCollection.8bf”
Nik 6 HDR Efex NO VERSION - from the file “NikCollection.8bf”
Nik 6 Perspective 6.8.0.2 - from the file “PhotoshopPlugin-filterNik 6 Perspective64.8bf”
Nik 6 Perspective automation 6.8.0.2 - from the file “PhotoshopPlugin-automationNik 6 Perspective64.8li”
Nik 6 Presharpener NO VERSION - from the file “NikCollection.8bf”
Nik 6 PresharpenerNik Collection 6stub NO VERSION - from the file “NikCollection.8bf”
Nik 6 Sharpener Output NO VERSION - from the file “NikCollection.8bf”
Nik 6 Silver Efex NO VERSION - from the file “NikCollection.8bf”
Nik 6 Viveza NO VERSION - from the file “NikCollection.8bf”
Nik Collection 6 Palette 6.8.0.2 - from the file “Nik Collection 6 Palette.8li”
Nik Collection Service NO VERSION - from the file “NikCollection.8bf”
Nik6BackgroundFilter NO VERSION - from the file “Nik6BackgroundFilter.8bf”
Nik6FineStructuresFilter NO VERSION - from the file “Nik6FineStructuresFilter.8bf”
Nik6HotPixelsFilter NO VERSION - from the file “Nik6HotPixelsFilter.8bf”
Nik6ShadowsFilter NO VERSION - from the file “Nik6ShadowsFilter.8bf”
Nik6SkinFilter NO VERSION - from the file “Nik6SkinFilter.8bf”
Nik6SkyFilter NO VERSION - from the file “Nik6SkyFilter.8bf”
Nik6StrongNoiseFilter NO VERSION - from the file “Nik6StrongNoiseFilter.8bf”
Note Paper 25.5 - from the file “Filter Gallery.8bf”
NTSC Colors 25.5 - from the file “NTSC Colors.8bf”
Ocean Ripple 25.5 - from the file “Filter Gallery.8bf”
OpenEXR 25.5 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 25.5 - from the file “Filter Gallery.8bf”
Palette Knife 25.5 - from the file “Filter Gallery.8bf”
Parametric Filter NO VERSION - from the file “MaterialFilter.8bf”
Patchwork 25.5 - from the file “Filter Gallery.8bf”
Paths to Illustrator 25.5 - from the file “Standard MultiPlugin.8bf”
PCX 25.5 - from the file “PCX.8bi”
Photocopy 25.5 - from the file “Filter Gallery.8bf”
Picture Package Filter 25.5 - from the file “ChannelPort.8bf”
Pinch 25.5 - from the file “Standard MultiPlugin.8bf”
Pixar 25.5 - from the file “Pixar.8bi”
Plaster 25.5 - from the file “Filter Gallery.8bf”
Plastic Wrap 25.5 - from the file “Filter Gallery.8bf”
Pointillize 25.5 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 25.5 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 25.5 - from the file “PBM.8bi”
PortraitPro 4.1.0 - from the file “PortraitProPSFilter64.8bf”
PortraitPro Body 3.1.0 - from the file “PortraitProBodyPSFilter64.8bf”
Poster Edges 25.5 - from the file “Filter Gallery.8bf”
Radial Blur 25.5 - from the file “Standard MultiPlugin.8bf”
Radiance 25.5 - from the file “Radiance.8bi”
Range 25.5 - from the file “statistics.8ba”
Render Color Lookup Grid 25.5 - from the file “Export3DLUT.8be”
Reticulation 25.5 - from the file “Filter Gallery.8bf”
Ripple 25.5 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 25.5 - from the file “Filter Gallery.8bf”
Save for Web 25.5 - from the file “Save for Web.8be”
ScriptingSupport 25.5 - from the file “ScriptingSupport.8li”
Service Nik 6 HDR Efex Filter NO VERSION - from the file “NikCollection.8bf”
Shear 25.5 - from the file “Standard MultiPlugin.8bf”
Skewness 25.5 - from the file “statistics.8ba”
Smart Blur 25.5 - from the file “Standard MultiPlugin.8bf”
Smart Photo Editor 3.1.0 - from the file “SmartPhotoEditorPSFilter64.8bf”
Smudge Stick 25.5 - from the file “Filter Gallery.8bf”
Solarize 25.5 - from the file “Solarize.8bf”
SP Substance Suite NO VERSION - from the file “MaterialSuite.8li”
Spatter 25.5 - from the file “Filter Gallery.8bf”
Spherize 25.5 - from the file “Standard MultiPlugin.8bf”
Sponge 25.5 - from the file “Filter Gallery.8bf”
Sprayed Strokes 25.5 - from the file “Filter Gallery.8bf”
Stained Glass 25.5 - from the file “Filter Gallery.8bf”
Stamp 25.5 - from the file “Filter Gallery.8bf”
Standard Deviation 25.5 - from the file “statistics.8ba”
Sumi-e 25.5 - from the file “Filter Gallery.8bf”
Summation 25.5 - from the file “statistics.8ba”
Targa 25.5 - from the file “Standard MultiPlugin.8bf”
Texturizer 25.5 - from the file “Filter Gallery.8bf”
Tiles 25.5 - from the file “Standard MultiPlugin.8bf”
Topaz B&W Effects 2 10.0 - from the file “tlbw2ps_x64.8bf”
Topaz DeNoise AI 18.0 - from the file “tltopazdenoiseaips_x64.8bf”
Topaz Glow 2 10.0 - from the file “tlglow2ps_x64.8bf”
Topaz Impression 2 10.0 - from the file “tlimpression2ps_x64.8bf”
Topaz InFocus 10.0 - from the file “tlinfocusps_x64.8bf”
Topaz Lens Effects 10.0 - from the file “tllenseffectsps_x64.8bf”
Topaz Photo AI NO VERSION - from the file “TopazPhotoAI.8bf”
Topaz Photo AI NO VERSION - from the file “TopazPhotoAIAutomate.8bi”
Topaz Sharpen AI 18.0 - from the file “tltopazsharpenaips_x64.8bf”
Topaz Simplify 4 10.0 - from the file “tlsimplify4ps_x64.8bf”
Topaz Star Effects 10.0 - from the file “tlstareffectsps_x64.8bf”
Topaz Studio 2 18.0 - from the file “tltopazstudio2ps_x64.8bf”
Topaz Texture Effects 2 10.0 - from the file “tltextureeffects2ps_x64.8bf”
Torn Edges 25.5 - from the file “Filter Gallery.8bf”
TPAIGatherImageDataFilter NO VERSION - from the file “TopazPhotoAIGather.8bf”
Twirl 25.5 - from the file “Standard MultiPlugin.8bf”
Underpainting 25.5 - from the file “Filter Gallery.8bf”
Vanishing Point 25.5 - from the file “VanishingPoint.8bf”
Variance 25.5 - from the file “statistics.8ba”
Water Paper 25.5 - from the file “Filter Gallery.8bf”
Watercolor 25.5 - from the file “Filter Gallery.8bf”
Wave 25.5 - from the file “Standard MultiPlugin.8bf”
WIA Support 25.5 - from the file “WIASupport.8li”
Wind 25.5 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 25.5 - from the file “WBMP.8bi”
ZigZag 25.5 - from the file “Standard MultiPlugin.8bf”
Optional and third party plugins:
GigapixelApplyImageDataFilter NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\TopazGigapixelAIApply.8bf”
GigapixelGatherImageDataFilter NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\TopazGigapixelAIGather.8bf”
Imagenomic Plug-in Console 1, 2, 0, 0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\Imagenomic\ImagenomicPluginConsole64.8li”
Portraiture 2.3.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\Imagenomic\Portraiture64.8bf”
ReDynamix 1, 0, 0, 1 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\redynamizer64.8bf”
ToonIt! 2.6.3 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\ToonIt.8bf”
Topaz Gigapixel AI NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\TopazGigapixelAIAutomate.8bi”
TPAIApplyImageDataFilter NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\TopazPhotoAIApply.8bf”
Duplicate and Disabled plugins:
GigapixelApplyImageDataFilter NO VERSION - from the file “TopazGigapixelAIApply.8bf”
GigapixelGatherImageDataFilter NO VERSION - from the file “TopazGigapixelAIGather.8bf”
LandscapePro 3.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\LandscapeProPSFilter64.8bf”
PortraitPro 4.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\PortraitProPSFilter64.8bf”
PortraitPro Body 3.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\PortraitProBodyPSFilter64.8bf”
Smart Photo Editor 3.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\SmartPhotoEditorPSFilter64.8bf”
Topaz B&W Effects 2 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tlbw2ps_x64.8bf”
Topaz Gigapixel AI NO VERSION - from the file “TopazGigapixelAIAutomate.8bi”
Topaz Glow 2 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tlglow2ps_x64.8bf”
Topaz Impression 2 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tlimpression2ps_x64.8bf”
Topaz InFocus 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tlinfocusps_x64.8bf”
Topaz Lens Effects 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tllenseffectsps_x64.8bf”
Topaz Photo AI NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\TopazPhotoAI.8bf”
Topaz Photo AI NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\TopazPhotoAIAutomate.8bi”
Topaz Simplify 4 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tlsimplify4ps_x64.8bf”
Topaz Star Effects 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tlstareffectsps_x64.8bf”
Topaz Texture Effects 2 10.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\tltextureeffects2ps_x64.8bf”
TPAIApplyImageDataFilter NO VERSION - from the file “TopazPhotoAIApply.8bf”
TPAIGatherImageDataFilter NO VERSION - from the file “C:\Program Files\Adobe\Adobe Photoshop 2024\Plug-ins\TopazPhotoAIGather.8bf”
Plugins that failed to load: NONE
SAME. Stuck in a perpetual state of face detection.
Face detection hanging is fixed in v2.4.0. Please update to the latest version and it will be working as expected.
Topaz Photo AI v2.4.0
Released February 29th, 2024
Windows: Download
Mac: Download
