Topaz Photo AI
- sometimes doesn’t recognize faces if they are not correctly positioned (horizontal or upside-down)
- not allows to correct the size and position of face frames
- sometimes makes good job on faces, but damages to the clothing
Topaz Photo AI
@remigiusz.grudzien Thanks for sharing your insights!
Can you upload some images where you’re running into these conflicts? We’d like to run some tests on our end and it’ll help us document this to create a solution.
NO - they are my customers’ photos
both colour and black and white, both slightly damaged and perfect pictures
face recognition still (in 2.0.1.) works on rectangle part of face - with no possibility of correction the area to recover the face
I understand this can be quite frustrating. Our developers are still investigating this. In the meantime, try turning off the Face Recovery filter for this particular photo and turn on the Upscale filter. That will enhance the resolution of the entire image.
