External Monitor
Is it possile to add a feature that allows me to use a reference monitor to view my workspace separate from primary monitor?
I would like to be able view my playback on my color correction reference monitor as it is calibrated, 10-bit monitor that can handle higher resolutions accurately.
How would this be different from just moving the entire app to that monitor?
It’s very convenient. Try to buy yourself a second monitor and you will understand.
I’ve already got three. Just trying to figure out what feature you think the app needs for a second monitor.
You’re talking about “workspace” and “playback” on the sperate monitor, for me it’s not clear, would you like having TVAI preview window can be seperated to put it on second monitor? Ok, but previews are stored as files on your volume and you can use Windows Explorer on the second monitor and play them with VLC
