This is not a new problem. It has never worked.
If the Audio mode is set to ‘Convert’ with an AAC codec and bitrate at 320kbps, Topaz Video AI will only export at 320kbps if the input video also has a 320kbps audio rate. Otherwise, it will use a variable rate somewhere between 220 and 290 and will never output at 320kbps.
