Export Progress Indicator
Version 3.3.0
I think I remember that Video.AI was giving me a progress indication when exporting a file. I switched to using “Export As…” so I could choose the destination of the render, but now I see no indication that a render is in progress, except for the fans on the CPU running like crazy, and a 0-byte temp file in the chosen folder.
Did I change something, or is this a feature and not a bug?
It appears the app is functional so I could be working on another clip if I wanted.
Thanks.
It’s possible that the task queue is currently set to ‘Previews’, which would not show any running or queued exports. Please check if switching to ‘All Outputs’ shows the current task:
Yes, that was it. Thanks for the quick response.
