Export from RW2 RAW
Hello,
I can’t export a RW2 image with the option “Preserve input format” or “DNG” in Topaz Photo AI 2.4.0. At the end of the processing phase, during the saving phase, the message “Error : DNG Write Error” pops.
With a JPEG export format, all is fine…
Steps to reproduce issue:
  1. Step 1 : open an RW2 (Lumix S5 Mark II X) image and process it
  2. Step 2 : click on “Save Image” button
  3. Step 3 : select “Preserve Input Format” or “DNG” in “Format” and click on “Save” button
Topaz Photo AI [v2.4.0] on Mac
  1. The original image file.
  2. The processed image.
Dropbox File Request
Hi,
I submitted the original image to your Dropbox, but, unfortunately I can’t with the processed image because I can’t save it.
Here is the error message I get when I try to.
Best regards
I have looked into this information and have learned that the Lumix S5 Mark II X is not currently supported by Topaz Photo AI.
We utilize a third-party software known as LibRAW for RAW file processing. We will need to patiently await an update from them regarding their RAW library before we can incorporate it into our software.
During this period, it would be necessary for you to convert those RW2 files into either TIFF or JPG format.
