Export As doesn't work right
Export As has been broken for a while for me. In 5.0.4 it just exports to the source location, exactly like Export would.
5.1 allows exporting to a different location, but it saves the file to the original location while working and once that’s done it moves the file to the location and name I told it to. That’s better but still wrong.
Export default is set to ( . ) After changing to another directory it defaults back to (.)
Default video settings:
Setting codec to FFV1 and changing profile to 10-bit-4.4.4 also reverts back to default 8-bit 4.2.0
Fresh install of 5.1.0 after removing with Revo
