Unfortunately, that new camera is not yet supported by photo AI. Hi,
We utilize a third-party software known as LibRAW for RAW file processing. We will need to patiently await an update from them regarding their RAW library before we can incorporate it into our software.
In the meantime, you will be able to edit your RAW files in it, however you will need to convert the files to DNG first.
If you have Lightroom Classic: On import, in Library, at the top will be the COPY AS DNG option. This will change all your files to DNG. Then you can invoke Photo AI with File > PLug in Extras.
If you do not have Lightroom Classic, you can use the free DNG converter, you can drop a folder, and it will quickly change them all to DNG.
