Error with no detail
I keep getting an error with no information or details as soon as i try to render or export any clips - it loads the model but thats all it does, then i get an error with no clue what is wrong
CPU: AMD Ryzen 5 3500X 6-Core 3.60 GHz
RAM: 8GB
Windows 11
Topaz Video AI v3.3.10
GPU: AMD Radeon R9 390 Series
logs.zip (76.3 KB)
Okay so ive figured out this issue only happens when i try to upscale, i can change other settings though
The logs are showing that this is an unlicensed copy of the app in version 3.3.10. Thats not going to have the app run as designed.
