Upscaling stops immediately and I get a well-intentioned message saying my PCM audio can’t be used in an mp4 container and so I should choose to convert audio in settings. I do this, but the error remains unchanged.
This isn’t a bug as PCM is not supported in a mp4 container.
Use convert to AAC and it will be fine.
I did that. Not fine.
Sounds like theres a problem with the source file then.
Or your file has drm protection.
Can you post a media info on the file.
The file was 1080p ProRes.
