Error running Model, on save
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Topaz Photo AI [v2.2.2] on [Windows]
2024-01-17-15-01-32.tzlog (45.4 MB)
lastSessionFiles.txt (33 Bytes)
if there are models missing on their computer (which you can check from the logs, it will show that a model is missing in the beginning of the log and try to redownload them)
  • run the installer again if the in-app model downloader is failing
  • troubleshoot security apps like antivirus, firewall, VPN
  • check if they have another internet connection they can use (hotspot usually works)
  • check if they have another computer they could try to see if it’s a computer issue or internet issue
Does this help?, from log:
[2024-01-25 09:53:41.807, 167.50 μs] [11fb8] Error | Exception: “AIProcessor failedunable to run model with index 0”
