Error in Export using "All GPUs"
I’m receiving error when trying to export with two GPUs, one RTX4070 and one RTX4060, both works fine separately.
logsForSupport.zip (23.8 KB)
DxDiag.txt (125.6 KB)
A bit offtopic, but just out of interest: How much faster is the 4070 vs. the 4060?
Hi, not very much! It’s a mistake comparing these two GPUs as gaming vs rendering cards. Combined they should nearly double the processing time.
Obs! SPAM-mappen kollas inte längre! Saknas svar, mejla då igen (från annan adress!).
| jo.vo Beta Tester
October 27 |
Correction: Double the processing SPEED;)
| jo.vo Beta Tester
October 27 |
Correction 2:
Double SPEED was a bit exaggerated, but something around ~1.5-7. I’ve made some tests where it looks like this:
Artemis/Low:
RTX4070: 2m9s
RTX4060(in PCIEx4G3): 4m4s
Iris/Low:
RTX4070: 7m34s
RTX4060(in PCIEx4G3): 7m48s
So it depends very much on what process You will run.
| jo.vo Beta Tester
October 27 |
Hi again, so on-topic, what is there to say concerning “All GPUs”? I purchased (3500SEK/~300USD) this extra graphics card in a strong belief that a RTX4060 should be able to co-exist/-work with a RTX4070 as they both use the same encoder, was I wrong in that assumption?
Correction 2:
Artemis/Low:
RTX4070: 2m9s
Iris/Low:
RTX4070: 7m34s
| jo.vo Beta Tester
October 27 |
Hi, and another “a bit off topic” reponse. I have now performed some tests with batch NVENC rendering. The result shows that I wasn’t that far off when I wrote “double SPEED”. The RTX4060 located in the PCIE16X4(3G3) socket finished the AV1-encoding process in 45s while the RTX4070 located in the PCIE16x16(G4)-socket finished in 43s.
Den lördag 28 oktober 2023 kl. 13:48:37 CEST, Jan Bang jan.bang@yahoo.se skrev:
Correction 2:
Artemis/Low:
RTX4070: 2m9s
Iris/Low:
RTX4070: 7m34s
| jo.vo Beta Tester
October 27 |
