Error: DNG Write Error
Topaz Photo AI fails to save processed DNG image to Lightroom Classic and return.
Steps to reproduce issue:
  1. From Lightroom Classic, edit a RAW file using Plug-in Extras => Process with Topaz Photo AI
  2. Let Photo AI process image. Click “Save to Adobe Lightroom Classic”
  3. Photo AI applies edits but fails to save with “Error: DNG Write Error”
Topaz Photo AI [v2.1.3] on [Windows]
I’m also having this problem, exactly as described. Also won’t write to a DNG when used separately from Lightroom, directly opening the file into Photo AI. Topaz has full file permissions enabled on my computer, M1 iMac
It seems like the issue is fixed in version 2.1.4.
I m having the same error with the newst 2.2.2 Topaz version :frowning:
any help or workaround? its frustrating…
@jose.l.cordova Could you please share the TPAI log file?
I run into the same problem editing .nef files created with my Nikon LS5000 Super Coolscan slide scanner. Moreover, these .nef are displayed much too bright when loaded as RAW in Photo AI. Update to Version 2.2.2 didn’t help.
I retested the scenario with .nef files coming from my Nikon D850 - they are displayed accurately and saved as .dng without problems.
For me, it seems that Tapaz Photo AI is not able to process my scanner .nef files since it doesnt know the specific RAW Format of the Nikon Super Coolscan LS5000 - still the reference in slide scanning though it’s no more produced. Maybe the problems described in the other posts have a similar background ?
@hermann.konrad
Topaz Photo AI | Windows Installer
Topaz Photo AI | Mac Installer
Topaz Labs | Support Page
