- Having successfully used the same preset many times, receiving error message on one particular file that is the same codec & resolution & approximate duration of the others.
- Apple M1 Pro 16GB. Mac OS 14.2.1
- Your log files (Help > Logging > Get Logs for Support). See attached.
- Any screenshots as necessary. See attached
logsForSupport.zip (12.6 MB)
This appears to be a permissions issue;
Try adding Video AI to the list of apps with ‘Full Disk Access’ in the macOS System Settings and restarting the app after: If this does not work, please proceed to a clean install which should reset the app’s permissions.
- Uninstall Topaz Video AI by dragging and dropping the app into the trash bin
- Delete the plist files & empty the trash bin
How To Delete Your Plist Files
- Reboot your Mac
- Reinstall
If that does not resolve the issue, send the updated logs to the support team at help@topazlabs.com
Thank you Kyle! That worked!
