Error: Connection handling canceled TOPAZ Video AI 6
Hi,
I would please be grateful for your help.
Video AI 6 shuts down when trying to import a video (the video shows briefly for 1 second before it stops and exits suddenly). I have tried to import models first, but it says “Error: Connection handling canceled”, and then stops and closes down. The intro page is stable but on attempting to use Video AI, it then shuts down. I have not had any previous issues using the current hardware.
I have a 9950X3D, RTX 5090, RAM - 6000MHZ 96gb (2x 48gb), Windows 11. Drivers up to date etc.
Internet is working and stable.
I am unable to provide screen shot as it closes down as soon as I upload a video/try to pre-load models.
Many thanks for your help.
Karl
In order to troubleshoot this, I will need your logs and your full system profile.
If you want to send them directly to the support team you can do so by emailing them to support@topazlabs.com.
This is usually the fastest way to get the logs to us for review.
Many thanks Kyle,
I hope you are well?
MANY apologies for the delay in sending, I have been busy and unbale to send.
I have enclosed the log zip file.
I have managed to download the models using the CPU (rather than the GPU) as the processor.
The PC comprises:
9950x3d
RTX 5090
96GB 6000MT/S DDR5 RAM (2 x 48GB)
Windows 11 (up to date)
Thanks for your help.
All the best.
Karl
(attachments)
logsForSupport.zip (7.3 MB)
