Enhancement of CLI
I would like the option to specify a “Remove” area on the command line - just a rectangular region in pixel coordinates with or without a final upscale. Also, it would be nice to be able to specify the upscale ratio on the command line, so I don’t have to change the registry before calling tpai.exe and then restoring it again afterwards.
Thanks for the idea and suggestion! Make sure that you do not forget to vote for your idea :slight_smile:
