Education | Using Super Focus With Underpowered Machine
How am I using Super Focus BETA incorrectly when I get results like this?
Hi.
Does your system comply with minimum requirements for Super Focus you really need at least recommended requirements
Here’s the link for you to check
Simply because, Super Focus needs a high end GPU with at least 8GB of VRAM to work properly or use the cloud
In addition, have you checked to see if you have the latest drivers installed
Filing that here’s the link to contact Topaz Support directly
Topazlabs Support
support@topazlabs.com
Hope this helps
@jackertrach seeing on our side that your computer only has 8GB of RAM, and 5GB of VRAM, the minimum RAW needed is 16GB, and VRAM 6GB. This will be especially important when using memory intensive tools such as Super Focus.
You can use the cloud render to use Super Focus, by purchasing cloud credits here: Topaz Labs | Cloud Rendering | Speed up your workflow - Available in Gigapixel 8 and Video AI 5
You can also test, if you have another computer that meets requirements, to render on that computer instead! Here are the requirements: System Requirements | Topaz Photo AI
Thanks!
