I can’t find a way to delete images and videos. Neither my source assets nor the generated assets. A 2025 post described a way to delete assets in the Bloom 2 app, but I don’t see it in the current Bloom2. I also don’t see a way to delete assets in the Standard Upscaler or Wonder 3.5 apps.
Hi genesmiller.
You can only Delete previous images and videos within the My Files option. Select My Files from the Menu then, a window will appear with all your previous files and beside the file name below each image you will see three small dots simply, Click on the dots and you will be presented with three options Download, Rename and Delete.
Hope this helps
