Education | How to prevent sample images from opening on startup
IF YOU HAVE AN ISSUE:
TO CREATE A FORUM TOPIC
  • Give as many details as you can on the issue you are experimenting.
  • Workflow steps you do, if using the standalone or plugin. File Type used is RAW or JPEG?*
Dear Topaz team,
Each time I open the programme, the sample images appear automatically.
Is there a way to remove them permanently?
Thank you,
Cristina
You can go into the preferences in Topaz Photo and toggle off the setting for the sample images. Next time you open the app, they won’t open in the filmstrip.
Thank you!
