Education | Enhancements Reapply Serially Too Often
The entire enhancement queue re-runs from the beginning too often. If I get rid of the last enhancement in a queue, it seems resource wasteful for my workstation to have to re-run every enhancement before it. The queue also has to go through its entire cycle again (including upscale which may take several minutes) just from clicking into and out of the export window. This significantly slows the work flow when I’m waiting for things to reprocess repeatedly.
Thank you for your feedback! To avoid reprocessing when zooming into the image, you can make sure to use the Fit View option, which will prevent unnecessary re-runs of the entire enhancement queue.
You can also go to Preferences > Application > General and set the Default zoom to Fit, then click Save. This will open the enhancement in Fit view each time you add it.
