I’ve just noticed this today. See Screen Capture below.
The ADJUST LIGHTING settings in the bottom, left corner doesn’t correspond to the setting in the ADJUST LIGHTING dialogue panel on the right. It gives it at 50,50,50 whereas it is 0. This only occurs on V2 and not on V1. Have I spotted a possible version upgrade in the future to V3 I wonder?
This would be expected behavior. V1 and V2 aren’t the same sliders, V1 is strength, and V2 is Exposure. 50% would mark the default middle mark, where it is currently. Then you can change this exposure and the grey number will update to the percentage marking where on the slider the setting is!
