Don't allow upgrades later than a users license
Don’t allow upgrades later than a users license. Really annoying that I had to downgrade after an upgrade. If I hadn’t had an internet connection, I’d have been screwed.
Hi there, we will always allow you to access builds that are released after your license has expired as this is the best way to know whether or not you want to pay for an upgrade license.
When you look at the upgrade options, it will state which updates you own and which ones you do not own.
If you update and wish to roll back, you can find the installer for your last owned version on the “My Products" page.
