Does Split View work for you?
I tried split view and it doesn’t work for me. In any other software the split view is to provide you the before and after view of what you can expect after processing, but in the case of Topaz Video AI both sides look the same to me. Does split view work for you?
What I have been using is an old software called VirtualDub (the mod that can open .mp4 files). With two instances I can open the old video and the enhanced video and compare an exact frame, before and after enhancement. However, this is very cumbersome.
From the description:
Split view
This will change the main display to show the
output of the left and right sides after processing.
Drag the divider in the middle to show more of the
image of the left or right side.
It does work for me…
I select “side by side” A and B
Click on A, set options, Preview.
Click on B, set options, Preview.
Then select Split View to slide over both views at once.
Here is a quick screen recording going over the preview options in Video AI v6. At the 1:25 minute mark I cover the split view and how to set that up to compare views from the original to an enhancement or compare two enhancements.
Previews in Video AI v6
Awesome, thank Kyle for the tutorial!
The whole process is such a mess, I cant ever be bothered to preview stuff I just make multiple renders and preview in another app. The 4 up view they had in about 2019 was way better than the current interface. No idea why they got rid of it it worked so well. I love topaz, the underlying product is so great, but the interface process is a total mess
Split view does not work for me. It has not worked for me. And still does not work for me for many versions. It shows the before twice which is useless. I just want to compare frames like the long ago version.
How are other people using this software? This has not worked for >1 year.
It works only for Nyx fast. No others.
