Hello everyone, it would be really nice if we could export the images of a film or video in DNG so that we can then work on it in Resolve. What do you think ?
did you mean PNG?
Not PNG I just say DNG
DNG it’s not available in Ffmpeg at least not with that name/abbreviation.
This are all the video, image and audio codecs available in Ffmpeg
Encoders:
V… = Video
A… = Audio
S… = Subtitle
.F… = Frame-level multithreading
…S… = Slice-level multithreading
…X… = Codec is experimental
…B. = Supports draw_horiz_band
…D = Supports direct rendering method 1
V…D a64multi Multicolor charset for Commodore 64 (codec a64_multi)
V…D a64multi5 Multicolor charset for Commodore 64, extended with 5th color (colram) (codec a64_multi5)
V…D alias_pix Alias/Wavefront PIX image
V… amv AMV Video
V…D apng APNG (Animated Portable Network Graphics) image
V…D asv1 ASUS V1
V…D asv2 ASUS V2
V…D libaom-av1 libaom AV1 (codec av1)
V…D av1_nvenc NVIDIA NVENC av1 encoder (codec av1)
V… av1_qsv AV1 (Intel Quick Sync Video acceleration) (codec av1)
V…D av1_amf AMD AMF AV1 encoder (codec av1)
V…D avrp Avid 1:1 10-bit RGB Packer
V…X.D avui Avid Meridien Uncompressed
V…D ayuv Uncompressed packed MS 4:4:4:4
VF…D bitpacked Bitpacked
V…D bmp BMP (Windows and OS/2 bitmap)
VF…D cfhd GoPro CineForm HD
V…D cinepak Cinepak
V…D cljr Cirrus Logic AccuPak
V.S…D vc2 SMPTE VC-2 (codec dirac)
VFS…D dnxhd VC3/DNxHD
V…D dpx DPX (Digital Picture Exchange) image
VFS…D dvvideo DV (Digital Video)
VF…D exr OpenEXR image
V.S…D ffv1 FFmpeg video codec #1
VF…D ffvhuff Huffyuv FFmpeg variant
V…D fits Flexible Image Transport System
V…D flashsv Flash Screen Video
V…D flashsv2 Flash Screen Video Version 2
V… flv FLV / Sorenson Spark / Sorenson H.263 (Flash Video) (codec flv1)
V…D gif GIF (Graphics Interchange Format)
V… h261 H.261
V… h263 H.263 / H.263-1996
V.S… h263p H.263+ / H.263-1998 / H.263 version 2
V…D h264_amf AMD AMF H.264 Encoder (codec h264)
V…D h264_mf H264 via MediaFoundation (codec h264)
V…D h264_nvenc NVIDIA NVENC H.264 encoder (codec h264)
V… h264_qsv H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (Intel Quick Sync Video acceleration) (codec h264)
VF…D hdr HDR (Radiance RGBE format) image
V…D hevc_amf AMD AMF HEVC encoder (codec hevc)
V…D hevc_mf HEVC via MediaFoundation (codec hevc)
V…D hevc_nvenc NVIDIA NVENC hevc encoder (codec hevc)
V… hevc_qsv HEVC (Intel Quick Sync Video acceleration) (codec hevc)
VF…D huffyuv Huffyuv / HuffYUV
V…D jpeg2000 JPEG 2000
VF…D jpegls JPEG-LS
VF…D ljpeg Lossless JPEG
VF…D magicyuv MagicYUV video
VFS… mjpeg MJPEG (Motion JPEG)
V… mjpeg_qsv MJPEG (Intel Quick Sync Video acceleration) (codec mjpeg)
V.S… mpeg1video MPEG-1 video
V.S… mpeg2video MPEG-2 video
V… mpeg2_qsv MPEG-2 video (Intel Quick Sync Video acceleration) (codec mpeg2video)
V.S… mpeg4 MPEG-4 part 2
V… msmpeg4v2 MPEG-4 part 2 Microsoft variant version 2
V… msmpeg4 MPEG-4 part 2 Microsoft variant version 3 (codec msmpeg4v3)
V… msvideo1 Microsoft Video-1
V…D pam PAM (Portable AnyMap) image
V…D pbm PBM (Portable BitMap) image
V…D pcx PC Paintbrush PCX image
V…D pfm PFM (Portable FloatMap) image
V…D pgm PGM (Portable GrayMap) image
V…D pgmyuv PGMYUV (Portable GrayMap YUV) image
V…D phm PHM (Portable HalfFloatMap) image
VF…D png PNG (Portable Network Graphics) image
V…D ppm PPM (Portable PixelMap) image
VF…D prores Apple ProRes
VF…D prores_aw Apple ProRes (codec prores)
VFS… prores_ks Apple ProRes (iCodec Pro) (codec prores)
VF…D qoi QOI (Quite OK Image format) image
V…D qtrle QuickTime Animation (RLE) video
V…D r10k AJA Kona 10-bit RGB Codec
V…D r210 Uncompressed RGB 10-bit
VF…D rawvideo raw video
V…D roqvideo id RoQ video (codec roq)
V…D rpza QuickTime video (RPZA)
V… rv10 RealVideo 1.0
V… rv20 RealVideo 2.0
V…D sgi SGI image
V…D smc QuickTime Graphics (SMC)
V…D snow Snow
V… speedhq NewTek SpeedHQ
V…D sunrast Sun Rasterfile image
V…D svq1 Sorenson Vector Quantizer 1 / Sorenson Video 1 / SVQ1
V…D targa Truevision Targa image
VF…D tiff TIFF image
VF…D utvideo Ut Video
VF…D v210 Uncompressed 4:2:2 10-bit
V…D v308 Uncompressed packed 4:4:4
V…D v408 Uncompressed packed QT 4:4:4:4
V…D v410 Uncompressed 4:4:4 10-bit
V.S…D vbn Vizrt Binary Image
V… vnull null video
V…D libvpx libvpx VP8 (codec vp8)
V…D libvpx-vp9 libvpx VP9 (codec vp9)
V… vp9_qsv VP9 video (Intel Quick Sync Video acceleration) (codec vp9)
VF…D wbmp WBMP (Wireless Application Protocol Bitmap) image
V… wmv1 Windows Media Video 7
V… wmv2 Windows Media Video 8
V… wrapped_avframe AVFrame to AVPacket passthrough
V…D xbm XBM (X BitMap) image
V…D xface X-face image
V…D xwd XWD (X Window Dump) image
V…D y41p Uncompressed YUV 4:1:1 12-bit
V…D yuv4 Uncompressed packed 4:2:0
VF…D zlib LCL (LossLess Codec Library) ZLIB
V…D zmbv Zip Motion Blocks Video
A…D aac AAC (Advanced Audio Coding)
A…D aac_mf AAC via MediaFoundation (codec aac)
A…D ac3 ATSC A/52A (AC-3)
A…D ac3_fixed ATSC A/52A (AC-3) (codec ac3)
A…D ac3_mf AC3 via MediaFoundation (codec ac3)
A…D adpcm_adx SEGA CRI ADX ADPCM
A…D adpcm_argo ADPCM Argonaut Games
A…D g722 G.722 ADPCM (codec adpcm_g722)
A…D g726 G.726 ADPCM (codec adpcm_g726)
A…D g726le G.726 little endian ADPCM (“right-justified”) (codec adpcm_g726le)
A…D adpcm_ima_alp ADPCM IMA High Voltage Software ALP
A…D adpcm_ima_amv ADPCM IMA AMV
A…D adpcm_ima_apm ADPCM IMA Ubisoft APM
A…D adpcm_ima_qt ADPCM IMA QuickTime
A…D adpcm_ima_ssi ADPCM IMA Simon & Schuster Interactive
A…D adpcm_ima_wav ADPCM IMA WAV
A…D adpcm_ima_ws ADPCM IMA Westwood
A…D adpcm_ms ADPCM Microsoft
A…D adpcm_swf ADPCM Shockwave Flash
A…D adpcm_yamaha ADPCM Yamaha
A…D alac ALAC (Apple Lossless Audio Codec)
A… anull null audio
A…D aptx aptX (Audio Processing Technology for Bluetooth)
A…D aptx_hd aptX HD (Audio Processing Technology for Bluetooth)
A…D comfortnoise RFC 3389 comfort noise generator
A…D dfpwm DFPWM1a audio
A…X.D dca DCA (DTS Coherent Acoustics) (codec dts)
A…D eac3 ATSC A/52 E-AC-3
A…D flac FLAC (Free Lossless Audio Codec)
A…D g723_1 G.723.1
A…X.D mlp MLP (Meridian Lossless Packing)
A…D mp2 MP2 (MPEG audio layer 2)
A…D mp2fixed MP2 fixed point (MPEG audio layer 2) (codec mp2)
A…D mp3_mf MP3 via MediaFoundation (codec mp3)
A…D nellymoser Nellymoser Asao
A…X.D opus Opus
A…D pcm_alaw PCM A-law / G.711 A-law
A…D pcm_bluray PCM signed 16|20|24-bit big-endian for Blu-ray media
A…D pcm_dvd PCM signed 16|20|24-bit big-endian for DVD media
A…D pcm_f32be PCM 32-bit floating point big-endian
A…D pcm_f32le PCM 32-bit floating point little-endian
A…D pcm_f64be PCM 64-bit floating point big-endian
A…D pcm_f64le PCM 64-bit floating point little-endian
A…D pcm_mulaw PCM mu-law / G.711 mu-law
A…D pcm_s16be PCM signed 16-bit big-endian
A…D pcm_s16be_planar PCM signed 16-bit big-endian planar
A…D pcm_s16le PCM signed 16-bit little-endian
A…D pcm_s16le_planar PCM signed 16-bit little-endian planar
A…D pcm_s24be PCM signed 24-bit big-endian
A…D pcm_s24daud PCM D-Cinema audio signed 24-bit
A…D pcm_s24le PCM signed 24-bit little-endian
A…D pcm_s24le_planar PCM signed 24-bit little-endian planar
A…D pcm_s32be PCM signed 32-bit big-endian
A…D pcm_s32le PCM signed 32-bit little-endian
A…D pcm_s32le_planar PCM signed 32-bit little-endian planar
A…D pcm_s64be PCM signed 64-bit big-endian
A…D pcm_s64le PCM signed 64-bit little-endian
A…D pcm_s8 PCM signed 8-bit
A…D pcm_s8_planar PCM signed 8-bit planar
A…D pcm_u16be PCM unsigned 16-bit big-endian
A…D pcm_u16le PCM unsigned 16-bit little-endian
A…D pcm_u24be PCM unsigned 24-bit big-endian
A…D pcm_u24le PCM unsigned 24-bit little-endian
A…D pcm_u32be PCM unsigned 32-bit big-endian
A…D pcm_u32le PCM unsigned 32-bit little-endian
A…D pcm_u8 PCM unsigned 8-bit
A…D pcm_vidc PCM Archimedes VIDC
A…D real_144 RealAudio 1.0 (14.4K) (codec ra_144)
A…D roq_dpcm id RoQ DPCM
A…X.D s302m SMPTE 302M
A…D sbc SBC (low-complexity subband codec)
A…X.D sonic Sonic
A…X.D sonicls Sonic lossless
A…X.D truehd TrueHD
A…D tta TTA (True Audio)
A…X.D vorbis Vorbis
A…D wavpack WavPack
A…D wmav1 Windows Media Audio 1
A…D wmav2 Windows Media Audio 2
S… ssa ASS (Advanced SubStation Alpha) subtitle (codec ass)
S… ass ASS (Advanced SubStation Alpha) subtitle
S… dvbsub DVB subtitles (codec dvb_subtitle)
S… dvdsub DVD subtitles (codec dvd_subtitle)
S… mov_text 3GPP Timed Text subtitle
S… srt SubRip subtitle (codec subrip)
S… subrip SubRip subtitle
S… text Raw text subtitle
S… ttml TTML subtitle
S… webvtt WebVTT subtitle
S… xsub DivX subtitles (XSUB)
A quick search says it’s a (probably proprietary) Adobe format based on the Tiff format.
My vote is to not pay Adobe any more money, and use tiff.
