DNG RAW workflow unusable in Photo AI 2.4.1
I shoot with Leicas that produce DNG-based raw files. When loading these DNGs into Photo AI or Gigapixel AI, and then exporting them, regardless of tool or action inside these two applications, even the faintest sharpening applied, the exported DNGs will be heavily altered and no match to the original DNG, rendering the workflow useless.
Steps to reproduce issue:
  1. Step 1
    Import Leica DNG.
  2. Step 2
    Add little sharpening or upscaling.
  3. Step 3
    Review exported DNG in your preferred editor (I use Capture One).
Topaz Photo AI [v2,4.1] on [Mac M1]
  1. The original image file.
  2. The processed image.
Dropbox File Request
Hi John,
Thanks for coming back to me. As it seems, DNG export from Capture One doesn’t work as it should. When using a DNG from direct from the camera, Topaz DNG workflow works as expected. Which leads me to to:
The bug is NOT on your side.
THANKS!!
Hans
