DNG files after processing in Topaz Photo AI,
I am happy with your program Topaz Photo AI.
I use Windows and Olympus camera with Raw files ORF.
After update I can’t get DNG files after processing in Topaz Photo AI, will it be possible again?
Are you using Topaz Photo AI as a plugin or as a standalone application?
Plugin
Sorry for my first answer
Both ways, but mostly standalone
Tage
If you are using your original ORF file while using Topaz Photo AI as a standalone application you can simply make you edits then click Export. You will be directed to the Export Settings where you will have the option to choose the Format to save your image. If you select Preserve Input Format for the ORF files they will be exported as a DNG.
Hello
Thank you very much it works perfectly
Tage
