I’m now on about the 50th photo in a single export, and Denoise in PhotoAI has started completely distorting mouths. It’s like it got a mind of its own and started shaping them as it sees fit. Rest of the pic it works fine but it goes mad with mouths.
IF YOU HAVE AN ISSUE:
- Make sure you check this post first:
====>> [CHECK THIS FIRST] 🚨- How to report a bug or issue for Photo AI - #3 - The fastest way to reach us is to send us an email at help@topazlabs.com
TO CREATE A FORUM TOPIC
- Give as many details as you can on the issue you are experimenting.
- Workflow steps you do, if using the standalone or plugin. File Type used is RAW or JPEG?*
