You need an option to change the vertical divider to even know there is a comparison before and after slider. I assumed it disappeared with the latest update. Its virtually unseeable
Hi.
Not having an issue using, seeing or finding the vertical slider never the less, I’m going to vote myself because, you’re correct needs changing and I would suggest perhaps a thicker line or even a brightly coloured one similar to the Guidelines in Photoshop any of these would help tremendously.
Don’t forget you can place a vote for your own suggestion just click on the blue vote box
