Hello,
Just got the Topaz studio and can’t login via mail on the Win apps.
Servers seems be ok.. says that invalid email or password but perfectly login on webnavigation.
Anyone have same issue?
Thanks
Nikita
Hello,
Thanks
Nikita
Now it says Password/Token jejected..
Hello Nikita,
We do not have any current server issues. To know what is happening mae sure to send to support@Topazlabs.com screenshots showing the in-app errors you get, and what email you are using to log in. You can also send logs from Help menu, Open logs folder and we can have a look!
