This would be possible, but quite tricky without improved document sizing options in Studio.
Basically, print will be determined exclusively by your PPI value, but since weâre not too concerned about printing, per se, Iâll focus on enabling you to deliver the âpreviewâ you seem to be looking for.
When you add a Digital Frame adjustment, it will occupy the existing canvas, and scale your image down a bit. This means that you can simply add the Mat and Frame dimensions to the dimensions of your image, and make that the ratio your images are cropped at. Hereâs what Iâd do, using your numbers:
- Start with 13x19
- Add 2.5 inches to each side, end up with 18x24
- Add 2 inches to each side, end up with 22x28
- Reduce your ratio, now you have 11x14
Now that you have the ratio youâll need, youâll want to do the following:
- Open your 13x19 image
- Add the Digital Frame Adjustment
- Select the Crop tool
- Enter the ration from above in the Custom Ratio setting: 11x14
- Apply the Crop, the Digital Frame Adjustment will update accordingly
- Set the Mat â Mat Width to 1.00
- Set the Frame â Frame Width to 0.65
This will set the mat and frame width so that it is as close as we can possibly come to something that resembles the dimensions youâll be working with:
Horizontal Values
1/11 | 5/44 | 13/22 | 5/44 | 1/11
9% | 11.3% | 59.1% | 11.3% | 9%
2in | 2.5in | <13in> | 2.5in | 2in
Frame| Mat | Image | Mat | Frame
Vertical Values
1/14 | 5/56 | 13/28 | 5/56 | 1/14
7.1% | 8.9% | 46.4% | 8.9% | 7.1%
2in | 2.5in | <19in> | 2.5in | 2in
This may be tough to read, but the first and second row show the ratios of what the frame, mat, and image will contribute to the âend resultâ.
The values I provided attempt to get this ratio as close as possible. Of course, as I mentioned, this isnât really workable or scalable. But, where thereâs a will, thereâs a way!
We have received requests to add a unit of measure other than sliders and cropping ratios, to Digital Frame. This feature request will take some time to implement, but weâre already working on improving document and saving controls, which will work very nicely with Digital Frameâs need to have those elements visible to the user (inches, PPI, document size, etc.).
