Different Default Face recovery strengths depending on face quality
When using autopilot, faces that are closer to the camera or those that are better quality tend to get enhanced better with higher strength. However, faces further away or just poorer quality would result in terrible, often very creepy, face recovery results. For those faces, I’d like to reduce the face recovery strength. It would be nice to set up certain thresholds on when to use certain face recovery strengths. After a certain level of missing information, I think it wouldn’t make sense to recover the face at all.
Thanks for the idea and suggestion! Make sure that you do not forget to vote for your idea :slight_smile:
