Hello. I first instaled a trial online version and later on as soon as I bought it, the program worked fine without the watermark in the pictures, so I didn’t install the full version.
Can anyone explain me the differences of the two versions (full is a much bigger file) and if I should uninstall the online version and install the full one?.
Usually, online and full (or offline) installers give you exactly the same application. The full one contains the whole application and doesn’t require an Internet connection to work, the online one starts off the installation process then goes online to download the rest of the code.
Another interpretation…I believe the “full” version is the entire file. The online update only includes new info or revises the existing files already installed.
This was my first topic and it was not easy to find it, but if you go to where the Topaz logo is (up, left), just press it and in the upper-right part of the new page you have a square with + New Topic.
