I have this file to denoise, only the ( black) text is not good to read after denoise and the preserve text option is a little bit off. The white text seems better.
I cannot put preserve text ( seems logic to me) on the first place… what is a solution? if any …
Steps to reproduce issue:
Step 1 drag raw from the RX10Ml4, a bit of unsharpnes is the corners.
Step 2 I tried to denoise, only the text is going down.
Step 3 change order places and shapening do not help.
Is this too bad or is anythind possible?
The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
