I’m finding DenoiseAI to be amazing for most of my images. My question is about the Sharpening aspect. Most recommendations generally suggest running DeNoise software as the FIRST step in a processing workflow and Sharpening as the LAST. I’m wondering how to reconcile these with DeNoise AI, or if it matters. Also, would it be even better to use DenoiseAI with zero sharpening and then run Topaz or another sharpener separately.
DeNoise AI will do the standard sharpening, and I have always found it serves my needs for that. You only really need Sharpen AI if you have images that have motion blur or are out of focus. In many cases, I have found that running Sharpen on an image that has a lot of noise that has been cleared up by DeNoise is rarely very successful anyway.
I found this Topaz video tutorial useful:
