I finally downloaded version 2 after I started the original thread on this topic over a month ago. This time it seems v 2 installed OK except for the fact that I got this error message. I hit Ignore. Everything seems to be working but you wonder when you get an error message like that if something didn’t install right. Am I safe using Denoise?
That .8bf file is a Photohop Plugin file.
Your Photoshop probably can’t find your DeNoise AI, but if you don’t need to use DeNoise as a Photoshop plugin you should be okay.
There is an article in the Help Center on how to fix it if you need it . How to fix your plugins on Windows manually or something like that.
