is it possible to expand Denoise AI and so on, so that I can also enter the number of percent manually behind the slider?
Slightly pushing the slider is difficult if I only want to adjust 1 or 2 percent.
It would be a relief if I could simply enter my desired number in addition to the slider.
Like Lightroom.
I donāt get the preview panel crash on Sharpen AI 2.1.5 and Denoise AI 2.2.9 as described, but whenever I down scale after an update I get the crash (using manual update). Only when app fully expanded as previously observed.
As an aside, I wish the Auto Mode and Auto Setting were ON by default, that would make more sense to me as a starting point.
Here is a short live screen capture (MP4) of DeNoise and Sharpen crashing when image is moved to the right edge of viewing pane. Download from my Box account: DeNoise and Sharpen crash to Windows 10 desktop
Please go to Help-> Graphics info, press copy and paste the info here. I suspect it is an issue with your AMD GPU. Are your drivers up to date from the AMD website?
I use NVIDIA and integrated Intel and have no more issues.
Hi Thomas, yes I see it happens but only if I am right at the edge of the view panel and then enlarge the Window (any type of image)ā¦ I get this error (v2.2.9):
Unhandled exception at 0x00007FFEC3CD284E (ucrtbase.dll) in Topaz DeNoise AI.exe: Fatal program exit requested.
I am currently working on this issue and have a fix at the moment. Iām going to clean this up and talk to the team about releasing an update either today or tomorrow to clean up everything.
It actually seems to be an inconsistent issue but is being addressed now and, as Adam said, we should have a fix either today or tomorrow. Probably tomorrow for me as it is nearly 10PM where I am ā¦
Yeah, itāll definitely be tomorrow for you. Building and releasing DeNoise and Sharpen takes several hours and I want to go over a list of issues and get as much as I can into this next patch. Unfortunately the past couple releases were rushed for authentication updates and then LR fixes, and I donāt want this one to be rushed as well.
Sure hoping ālast filterā in Photoshop starts working. No pressure. Just casting my hopes, dreams, and wishes out into the bottomless void that is the internetā¦
