I am using TD to process images 5184*3456 px, RAW cr2 from a Canon D7. Win 10 64 bit. RADEON RX 580 with AMD reporting 8GB RAM. Drivers up to date.
Win 10 Sysinfo shows Adapoter RAM = 1,048,576 bytes (???)
So, the symptoms.
- TD is VERY slow. It takes more than a couple of minutes to process the photo, then 15-20 minutes to Save.
- if I use other programmes while processing, and in particular Firefox, either one or both will crash pretty much repeatably within little time of my firing up FF.
- I finally made as sure as I could that I had downloaded all models, set GPU Memory to medium in the hope of stabilising things, and started a save and went to bed. Upon waking I found that TD had produces a dng with a resolution of 256 *1712 px! (source was TIFF and I had made no changes, although I did not specifically press the button to preserve input )…this was the first time THIS had happened to me
So. Help please.
Nick
