It’s not as pixelated as the preview but it’s still really bad results. Here are my tests from Sharpen AI - I uploaded the original image, a screenshot of the pixelated preview, the automatic settings selection output, and then a test with manually selecting the focus setting.
How do I open a ticket? I desperately need to talk this through with someone and get all this working again!
Is this upgrade ready for prime-time… seems like a lot of bad experiences. My upgrade button does not work either.
While I now have Denoise AI 3.0.2 working, unfortunately, OpenVINO isn’t working. It also doesn’t work in Sharpen AI 3.0.0.
The system is Windows 10 Pro x64 2004.
I have Topaz Video Enhance AI 2.1.0.0b running on the same system, and there, OpenVINO works very well.
Check the attached logs. Even though “CPU” is selected for “AI Processor” in Preferences, it’s loading the Tensorflow .bin files, not the OpenVINO ov.rz files.
2021-03-25-02-10-47-Main.tzlog (58.7 KB)
2021-03-25-02-10-47-QML.tzlog (26.7 KB)
Line 248:
2021-03-25T02:11:17.968 [Warning] Thread: 0x146c7ec32e0 <TDenoiseWorker::procMatAIClear line #: 344> Already known that OpenVino cannot work. Will fall back to tensorflow!!
In the registry, under HKEY_CURRENT_USER\SOFTWARE\Topaz Labs LLC\Topaz Denoise AI\appMain, DWORD cpuPlugin is set to 1. I believe it should be 0 for OpenVINO. If I change it to 0 it will just get changed back to 1. However, String ifOpenVinoCanWork is set to true.
The performance difference is extremely obvious… minutes instead of seconds!
I have more info posted for Sharpen AI 3.0.0 here → https://community.topazlabs.com/t/sharpen-ai-v3-0/21316/35
I’m pretty sure that the RTX driver is loaded for both cards. Which possibly makes it even more curious why the program works with the Quadro but fails with the RTX card.
Which driver are you using?
Having followed all the above discussion I still do not understand if it is OK to use the latest Denoise AI version on my Windows 7 machine.
Do I have to wait until the “legacy” installer is again available?
I am very happy with how 2.4.2 works; will the new version offer somewhat reduced functionality when running on Windows 7?
Thank you,
Massimo
This latest version does not appear to be any faster, still takes about 5 minutes to process a image (pity there is no process bar, so that you would know if it was doing anything), but it gets there in the end. Good job it is only the occasional image that I use this program for. But saying that it does do a good job. I have turned auto preview off and switched to CPU.
With my 5 years old (GTX 1080) gpu it takes 8 seconds.
And on my big machine it takes 3 - 4 seconds per image. (Two GPUs)
I could trow in a 6 years old GPU and i bet that one will also work.
The big differene is that everything is up to date.
And i really don’t get why they did support win 7, 8.1 is ok but 7 even don’t get anymore updates from Microsoft…
Realtime, that was in the Beta.
22 MP image, two gpus (like 2080S GPU)
Strange, with a GTX1050 my system is blindingly fast using 2 GPUs (Integrated Intel HD630) and no problems with previews or output. Make sure that if you use NVIDIA that you check your driver version, the latest for the 1050 is 461.92
Note that I also use as a plugin to Affinity Photo and Capture One and don’t have any issues there either.
When I should update DeNoise 3.0.2 my computer CRASH and restarts during the installation
I have a iMac 27" late 2012, OS Catalina 10.15.7
What is the message during the install process?
It’s a grey screen with message “Your computer has a error…” and restarts.
Version 3.0.2. Using my GPU (GTX580) results in a processing error every time. Using CPU (i9-9900k) is much slower. There also seemed to be an issue with the preview not updating (manual mode) if I moved my mouse…perhaps when moving it off of the Denoise window.
I had to revert back to 2.4.
I love DeNoise, but this release was a step backwards for me.
Hall. Nach dem Updat auf 3.02 läüft das Programm unglaublich langsam. Die Endspeicherung dauert Ewig lange. Wie kann ich auf die letzte Version zurücksetzen??? So wie jetzt geht das gar nicht!!! Gruß…
Hi, welche Grafikkarte, Betriebssystem und CPU nutzen Sie?
Und welche Version haben Sie heruntergeladen?
Hello, update made and of course now it’s not working anymore nice … why ?
Could you explain your issue more?
Common debugging steps so far are to update your graphics driver if it’s not up to date already. Also we’ve found a performance issue on older Macs that we are working on resolving. If either of these isn’t your issue I’d need more info.
