Deinterlace and keep original frame rate (not field rate)?
I often need to de-interlace, but I rarely actually want the full 59.94fps. As soon as I set an interlaced enhance mode the frame rate goes to 59.940 and clicking 29.97 just flips immediately back to 59.94. I’m assuming if I could just discard the extra frames it would also process much faster since it’s basically making half as many frames.
here you go.
