Curves Filter Problem Studio 2.0.5. Each time I’m trying to adjust a picture with Curves Filter the whole Curves windows is moving. It adjust a little and then locks in and the window moves while holding a mouse so You can’t keep adjusting while holding a mouse. You need to release mouse button then adjust a little the redo the whole process.
Please raise a support request on the main website.
I will but I want to know if others have same problem
Yes it does seem to be an issue … @russelltarpley can you have someone look at it as it drags about in the Filter?
I Let them know about that.
Where exactly did you click? I am having a time trying to get mine to drag as shown in your screen shot
It happens on my travel laptop too. Will look at it tonight and see if I can help explain.
You just select the triangle or you select position on the line.
No problem here with Studio 2.0.5. Everything stays in place as it should no matter where I click. (Win 10 - 1803, Desktop, Nvidia GTX980, 425.31 drivers)
What version of Studio?
Because I have two computers and both acting the same way.
And you trying the Curves Filter?
Windows 10 here, version 2.0.5 and the latest from source that is about to release are not doing it for me. Do you have a dedicated graphics or running an integrated intel chip like the 600 series?
No I’m using Nvidia Video Drivers.
One is MS book Pro and the other is a Gaming Machine with very powerful Nvidia Card
Application & Version: Topaz Studio 2 Version 2.0.5
Graphics Hardware: Intel(R) HD Graphics 615
OpenGL Driver: 3.3.0 - Build 25.20.100.6617
CPU RAM: 16248 MB
Video RAM: 1500 MB Total, 1024 MB In Use
Preview Limit: 3135 Pixels
My desktop is okay but same behavior on this laptop too:
Graphics Hardware: GeForce GTX 1050/PCIe/SSE2
OpenGL Driver: 3.3.0 NVIDIA 398.11
CPU RAM: 32619 MB
Video RAM: 4096 MB Total, 3691 MB In Use
Preview Limit: 6262 Pixels
Perhaps it’s related to touchscreen functionality?
I have a desktop and same problem.
and this laptop too with V2.0.6
Application & Version: Topaz Studio 2 Version 2.0.6
Graphics Hardware: Intel(R) HD Graphics 630
OpenGL Driver: 3.3.0 - Build 24.20.100.6286
CPU RAM: 16195 MB
Video RAM: 1500 MB Total, 1200 MB In Use
Preview Limit: 3466 Pixels
In my case click and drag the curve or click and drag the end points it happens on both my PC’s, both using NVIDIA.
No problem with 2.0.6 here.
You keep saying no problem so can you help with posting your Graphics info. Go to Help->Graphics info click Copy and paste the details here please.
