Hello, I don’t know if this question was answered already, I did look but when I try to crop in Studio to an 8x10 and I click done, Ok and the photo goes back into PS it is stretched/distorted. I am clicking on 8x10 and I’m going crazy trying to figure this out.
If you are using Studio as a plugin don’t Crop in Studio as PS passes a fixed sized layer and will stretch the returned image to fit in the layer/image dimensions in PS.
As cropping is a Image action make sure you do the crop in PS when the layer is returned.
Should you use Studio as a standalone the the image will be cropped accordingly before being saved.
