Imagers attached show different steps, Topaz correctly shows image to be saved. Photoshop shows wrong part of image actually saved.
Topaz Photo AI [v3.03] on [Windows]
Which plugin are you using for the Photoshop plugin:
I was using Topaz Photo AI, saved DNG, then opened that with Photoshop.
