Crop function not setting correct aspect ratio
When working with multiple images, the crop function does not set the correct aspect ratio of the images:
Setting the Aspect Ratio to 16:9 should produce an image of around 7680x4320.
However, the image saved will be 7680x4304 - which is not even close to 16:9.
Sometimes the output image is out even further.
Note that this functionality works fine in 6.3.3.
Thank you for bringing this to our attention.
This is a known conflict and our developers are investigating the cause now as this is a major priority.
You can see the active post here:
What is the status of this bug? It’s still an issue for me…
as of v7.1.3 this is still an ongoing issue.
We still have users reporting aspect ratio is off by one pixel. We are hoping to get this resolved in the near future.
thank you for checking in!
