The bug / behavior you have encountered
TVAI shows Error in the exports list, when the export is most of the way through a 2x upscale and converting to 120 fps. This is working on a TB VR video with a resolution of 1920x2160, i.e: 2x1080p. The models used are Nyx and Aion.
I have had this issue using the same file 4 times. -
Your system profile
Intel i5-13600K, 128GB DDR4-3200, 3090 24GB, 2x2TB SSDs, 3060 12GB (not used to TVAI). I have changed TVAI to use the 3090 specifically.
The latest BIOS is has been applied and I have had no instability or issues otherwise. LLM’s and various AI Models run fine locally. -
Your log files (Help > Logging > Get Logs for Support)
logsForSupport.zip (214.5 KB) -
Any screenshots as necessary
If needed I can provide the source file I am testing with.
The 3090 memory set to 90% and using Chronos Fast succeeded.
I am trying Aion again if it works with the exact same config as Chronos Fast on 90% Memory.
Log snippet:
2024-10-15 03-40-12.558 Thread: 5556 Info ---> handleUpdateInfo( 50 )
2024-10-15 03-40-13.148 Thread: 5556 Info FF Process Output: 50
2024-10-15 03:40:13 13444 CRITICAL: Can't sync TensorRT output :
2024-10-15 03:40:13 28080 CRITICAL: Can't sync TensorRT output :
2024-10-15 03-40-13.148 Thread: 5556 Info FF Process Output: 50 2024-10-15 03:40:13 10048 CRITICAL: Can't sync TensorRT output :
2024-10-15 03-40-13.150 Thread: 5556 Info FF Process Output: 50 an illegal memory access was encounteredan illegal memory access was encounteredan illegal memory access was encountered
